It is currently Thu Aug 14, 2025 9:37 am
PostPosted: Fri Sep 04, 2015 10:23 am
Cooperstand Pro-G
$48.95
The Pro-G Stand is fabricated from sustainable solid African Sapele hardwood. Pro-G is designed to temporarily and securely support a stringed instrument in a protected or monitored environment. Pro-G is intended for solo performances, studio, home and display use.
Pro-G supports acoustic guitars up to 5” thick, electric or bass guitars up to 2 ¼” think, ukulele, mandolin and more. The classy highly stable design enhances the professionalism of the performer, and then neatly packs away in most guitar cases or gig bags.
Because of the physical nature of this product it could be damaged if accidentally stepped on. As a result, it is not recommended that it be used for abusive on stage use. See our Ecco-G or Duro-Pro composite line for heavy stage use.
http://rctonewoods.com/RCT_Store/cooperstands-c-178/
Four colors available
